Lage T2's DEEL 2
Diederik
Re: Lage T2's DEEL 2
Bericht door Diederik » vr jul 22, 2011 22:14 pm
los limbos schreef:T2D creation, it's me style..
Voor een B... lekkuh! :mrgreen:
los limbos
Bericht door los limbos » vr jul 22, 2011 22:18 pm
Speciaal voor Died :wink:
Nog een mooie T2B, van onze zuiderburen...
Diederik
Bericht door Diederik » za jul 23, 2011 13:37 pm
los limbos schreef:Speciaal voor Died :wink:
Bedankt he! :mrgreen:
Diederik
Bericht door Diederik » za jul 23, 2011 13:43 pm
Narrowed and C notched and fitted 9x15s with 265/50/15s in the rear and 8x15 in front.
Diederik
Bericht door Diederik » za jul 23, 2011 13:45 pm
jamracing schreef:I've been getting alot of questions abut my bus and here's the advise that I am sending out:
My bus is a 71 so it came with factory disc brakes. Heres what I did to lower my bus.
I got a WagonsWest 4 inch adjustable beam, WW drop spindles and narrowed tie rods for the front. It is adusted in the middle setting so I can go up about 4 inches and down about 4 more inches.
Now in the rear, I used the WW 3.25 horse shoe plates. When I put the plates on, it wasn't as low as I wanted it. After some reasearch, I found the last owner had adjusted the spring plates to raise the rear because it was "saging". So I readjusted them back down 1 noch. The Fuchs are Empi reproductions and are a direct bolt on the 71 bolt pattern.
Now keep in mind, You are lowering a Bus that is 40+ yrs old. While doing it I also found I had to replace the ball joints, tie rod ends, brake master cylinder, parking brake cables, rear brakes, backing plates, wheel cylinders, brake hoses, ect. The price of these items adds up.
If you take your time and do it right, be sure you do an alignment afterward, It rides real close to stock, with no rubbing or bottoming out issues.
Good luck and have fun,
The Duke
Dubbel schuiver
Bericht door Dubbel schuiver » zo jul 24, 2011 13:18 pm
Groetjes Patrick
Constructam Comet 5 1970
Dit is mijn busverhaal
Next_Racer
Bericht door Next_Racer » zo jul 24, 2011 21:20 pm
Net klaar. Enkel de huif moet er nog op gezet worden
Panel Bas
Bouwjaar Bus: 1968
Bericht door Panel Bas » zo jul 24, 2011 22:02 pm
Next_Racer schreef:Afbeelding
bus-loos.
los limbos
Bericht door los limbos » zo jul 24, 2011 22:05 pm
Diederik
Bericht door Diederik » ma jul 25, 2011 15:31 pm
Pickup en doka-tijd zeker...? :mrgreen:
De blauwe en de bruine zien er beide stoer uit! =D>
westy69
Bericht door westy69 » ma jul 25, 2011 15:41 pm
Pick-up, Doka's tijd en .... #-o
Diederik
Bericht door Diederik » ma jul 25, 2011 18:56 pm
westy69 schreef:Pick-up, Doka's tijd en .... #-o
WTF? :shock:
Diederik
Bericht door Diederik » ma jul 25, 2011 18:57 pm
los limbos
Bericht door los limbos » ma jul 25, 2011 20:31 pm
Pick-up, Doka's tijd en .... :wink:
westy69
Bericht door westy69 » di aug 02, 2011 14:29 pm
AP Pacer rims 15 x 5"
